need parts for a 1996 sidekick/sunrunner where can I find them
  • 1850 Views
Offline roxiedog13
I need a Mass Airflow sensor, timing belt, steering cross link and extended front brake lines( aftermarket for sure)
I'm from Canada but any reference will work, local better obviously
Offline JollyZuk
  • 284
Re: need parts for a 1996 sidekick/sunrunner where can I find them
« Reply #1 on: July 20, 2022, 01:57:13 AM »
RockAuto would be a good source for the maintenance/repair parts.  I am also in the market for extended brake hoses, and have not found a solution.  Low Range Off Road used to have them, but last I checked, no longer carries them.  For the rear brake line, you can use an extended Samurai rear brake hose...the stock hose is the same.  That is what I did for the rear on mine.  For the fronts, still trying to figure that out.  I put GM W body struts on the front of my 'Kick, and so I cut the brake line retainers off of my old factory struts and welded them to the new struts, and was able to get a little more slack when I did that, but not as much as I would like with 4" of lift.
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline JollyZuk
  • 284
« Reply #2 on: July 20, 2022, 02:04:01 AM »
I stand corrected on front brake hoses...
https://lowrangeoffroad.com/suzuki/sidekick-tracker-x90-escudo-vitara-sunrunner-1989-1998/brakes/sidekick-tracker-extended-front-brake-lines.html
I had emailed LROR a while back, and was informed that they were no longer stocked...this shows low stock, but maybe you will get lucky!
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline JollyZuk
  • 284
« Reply #3 on: July 20, 2022, 06:12:35 AM »
 Correction #2.  Turns out even though the "Headline" is extended front hoses, if you read the description, they are stock length.  Comparing specs from RockAuto, that appears to be the case.
1995 Sidekick JLX
OEM ROOF RACK!!!
