Technical Discussion - Beginner / Repair
96 Sidekick JX 2 door4x4
DesertFox48
6
ZUKIWORLD Online!
August 26, 2021, 09:49:58 AM »
Hi Guys,
I am looking for a rear drive shaft for my Sidekick. It is an AT and the rear shaft. I don’t care if it is used or new. Any ideas as to where I can get one. Thanks.
Dughrt
34
ZUKIWORLD Online!
Re: 96 Sidekick JX 2 door4x4
August 26, 2021, 02:03:31 PM »
Depends on your location. I have one in Oregon, there is a guy near Tacoma that has alot of parts. Hwy 83 Suzuki sells alot of used parts, Also trail tough has some used stuff. Heck even try your local pick a part yard.
JollyZuk
284
4
ZUKIWORLD Online!
August 26, 2021, 06:15:53 PM »
What has happened to your existing shaft? Double check my info, but I believe you will need to make sure you get a shaft for a 96+ rig, because the outputs on the transfer case changed in 96.
1995 Sidekick JLX
2" Spacer lift, XL7 rear springs, 2nd Gen front springs, W-Body GM Struts on front
OEM ROOF RACK!!!
DesertFox48
6
ZUKIWORLD Online!
Reply #3 on:
September 04, 2021, 08:05:20 PM »
DUGHRT
How much do you want for the drive shaft? I will buy it from plus shipping of course.
DesertFox48
6
ZUKIWORLD Online!
Reply #4 on:
September 04, 2021, 08:07:04 PM »
JOLLYZUK
When the old drive shaft gave way it hit pavement pretty badly and is all tore up on the ends.
