Last night I got the alternator bracket fixed but there's still not much room between the alt fan and the water pump pulley.
The wiring directions I found kept talking about a red/white wire but my wires were different colors and there was actually 3 wires coming from the plug but 1 was cut, so I started stripping tape back and find this lol
I am not sure exactly where this thicker wire goes, it runs into a bundle that then runs inside the cab, when installing a bigger alternator I usually run bigger wires to the battery, I am not sure if I should/could get rid of this wire or if I should just piggyback a bigger wire from alt direct to the battery.
and while tracing that wire I found these behind the battery, so I will fix them before they create bigger issues
