Engine Codes
  • 677 Views
Offline GrapplingDMC
  • 10
Engine Codes
« on: December 17, 2020, 02:46:13 PM »
I bought a 2009 XL-7 that had a bad motor from the timing chain. I had a 2007 motor in & had the updated timing chain & tensioners and all that replaced at the same time. I am getting 4 current codes. P0420, P0009, P0018 & P0019. The car starts hard when I get fuel so most likely the purge valve which i am guessing will take care of the P0420 code. The car seems to run great besides that. Has anyone else had similar issues with the other 3 codes?
  • 10
Re: Engine Codes
« Reply #1 on: December 22, 2020, 03:29:29 PM »
Ok update. I deleted the codes & the light came right back on. I ran it for a couple days & the codes now are the P0009 & P0018. Any thoughts?
  • 10
Re: Engine Codes
« Reply #2 on: December 26, 2020, 12:13:52 PM »
Update number 2: I changed the crankshaft sensor (which was buried & took 4 hours on a lift). Deleted the code & drove about 30 miles home with no code.
 Woke up the next day started the rig & code came on before I was out of the driveway. I am wondering if maybe the cam sensors can throw that code. Thoughts?
