Technical Discussion - Performance / Modify
1988 Suzuki Samurai 1.3 4X4 No Spark
SybilsWays
ZUKIWORLD Online!
February 17, 2020, 01:56:05 PM »
We installed a used engine that and after install it started but the water mixed with the oil. I took the head off and had it checked along with a valve job. Put it back together and now no spark.
The distributor rotor is turning, we have power to the coil and no spark.
What are your thoughts?
fordem
4314
167
Re: 1988 Suzuki Samurai 1.3 4X4 No Spark
February 17, 2020, 05:40:15 PM »
Check for spark at the coil - if you're not getting a spark there you most likely have an electrical issue, if you have a spark there but not at the plugs, the distributor is probably installed incorrectly.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
