Weird Electrical prooblem
  • 1196 Views
Offline RJkick
  • 631
« on: December 16, 2019, 12:00:28 PM »
I was connecting some extra lights yesterday and thought the relay was bad so changed the inline fuse and relay.  I could hear electrical crackling when I connected the relay but made double sure the ends were connected correctly.  Now my Headlights, Radio, and Dome appear to have stopped working.  Fuses seem good so could it be a burned out bulb or some other fuse?
Any ideas or direction to start?
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
  • 4314
  • 167
Re: Weird Electrical prooblem
« Reply #1 on: December 16, 2019, 02:34:21 PM »
Yes - get yourself  a meter and learn how to use it.
In my book fuses are either good or they're not - "seemed" is not an option - you can check them with a meter in a matter of seconds, and the same goes for the bulbs.  Look closely at the back of the fuses - there are contact points that you can reach with the meter probes, you don't even need to pull the fuse from the circuit to test it.
Headlights, radio & dome are on different fuses, in fact, each headlight has it's own fuse - if I recall correctly the radio has two power connections, one that powers the radio itself, and a second that powers the radio's memory circuits, and this last one might be the dome light circuit - but the radio will not power on unless both circuits have power.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline RJkick
  • 631
« Reply #2 on: December 18, 2019, 09:15:19 AM »
I'll start there. Thanks
More to follow
Offline RJkick
  • 631
« Reply #3 on: December 23, 2019, 08:57:11 AM »
Turned out to be a 40amp fuse under the hood
Thanks
