Can I spray 2K clear over a Duplicolor base coat?
  • 1945 Views
Offline RalphARoni
  • 83
« on: November 28, 2019, 08:41:43 AM »
Can I spray 2K clear  over a Duplicolor base coat without compatibility problems? I know to let the base cure for a week first. I would use the Duplicolor clear but I have seen what chemicals will do to it.
'96 Geo Tracker 2 dr auto 4wd 15" wheels, 23" tires, named "GT" and towed behind the motorhome
Re: Can I spray 2K clear over a Duplicolor base coat?
« Reply #1 on: November 30, 2019, 09:04:35 AM »
Are you trying to keep the color?
Offline RalphARoni
  • 83
« Reply #2 on: December 01, 2019, 07:02:39 AM »
Not sure what you are asking. Sorry.. I hope to keep the hood the same color and just sand the bad clear then use 2k. That would work but I am afraid that I will need to go down through the existing black color (not original) and repaint with a matching duplicoloer (acrylic lacquer) and clear coat. I wonder if I can use 2k as the clear for durability and solvent resistance or whether I have to use the Duplicolor for clear. It doesn't need to be perfect but I'd like it to look pretty good. Hope that answers the question.
Offline JollyZuk
  • 284
« Reply #3 on: December 04, 2019, 01:14:16 PM »
Are you using a 2 stage base coat?  If you are using a single stage base, not really sure.  I would discuss with your paint supplier...
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline RalphARoni
  • 83
« Reply #4 on: December 05, 2019, 06:55:30 AM »
:laugh: Advance Auto doesn't know anything about the rattle cans.
