Gas Tank Inlet Valve
  • 1646 Views
Offline RJkick
  • 634
« on: November 07, 2019, 06:42:25 PM »
I have a 1992 4dr JLX.  The Gas Tank was repaired and they lost the Gas Tank Inlet Valve.  They had the Tank for 2 months and I can't remember something
Does the Inlet Valve have a plastic ball in it?  It seems when I go uphill Gas is leaking out of the tank and hose connection.  Never use The Radiator Man shop
I can't even find anywhere to buy one used or new
Re: Gas Tank Inlet Valve
« Reply #1 on: November 21, 2019, 03:30:04 PM »
That certainly should not be happening, where is it leaking fuel out of?
You can see the fuel system configuration over on the FSM for the Vitara (European Sidekick/Tracker) on Rhinoman's website on page 335:
http://www.rhinoman.org/manuals/vitara/vit_manuals.html
Offline RJkick
  • 634
« Reply #2 on: November 25, 2019, 08:21:34 AM »
I put on a longer hose since I have a 3" body lift.  Hopefully I'm good to go now
« Reply #3 on: November 26, 2019, 01:16:34 PM »
Let us know!
