That should be fine. Remember that when you install it in the front you will get a taller lift due to the angles vs the rear. The front usually sits lower anyway, so it levels things out nicely.
If you find your topping out your struts when coming off bumps you might want to install a 1" spacer lift on the front struts as well.
