1996 Sidekick half-cab ARB lockers AWESOME OFF-ROAD MACHINE
  • 877 Views
Offline GREENKICK
  • 14
1996 SUZUKI SIDEKICK 4x4 half-cab, awesome off-road machine, this thing is like a street legal side-by-side with ice cold air conditioning.
ARB air lockers front and rear, ARB air compressor able to fill up large tires. 5:13 gears front and rear, both differentials rebuilt with all new bearings and seals when the 5:13’s and air lockers were installed, also has the hard to find steel front axle housing.
The transfer case was rebuilt with the 4.24 low range gears installed.
The transmission was rebuilt to factory specs.
The engine had the timing belt, water pump and front seals replaced, the a/c system was completely removed and rebuilt (I had the shop pull the dashboard out in order to clean and/or replace all the a/c parts, new compressor, new vents,  new evaporator, etc.)
Installed the larger 4 door front brake rotors, calipers, hangers, pads.
Installed rear disk brakes with the factory parking brake handle still being used.
Installed Rally tops half-cab conversion, snorkel, off road lights front and rear, stereo with back-up camera, 4,000 lb. smittybuilt winch, warn premium hubs, remote transmission oil cooler, Zuks off road seats/brackets, 126,000 miles
Installed new 33x12.5x15 super swamper radials with new Mickey Thompson aluminum wheels.
Installed new steering bars/arms, installed new control arms (three in the rear, two in the front) new front ball joints, new rear shocks.
Installed new GM high amp alternator
Windows tinted including the windshield which has clear “blue air” tint which keeps out UV rays and a lot of the heat
Calmini skid plates for the tranny and transfer case.
Paint has light scratches from driving through the bushes, but NO RUST!!!!!!
All work professionally done.
Truck is in Florida 32940
I have about $22,000 in this one of a kind machine
$12,000 takes this home
Offline GREENKICK
  • 14
Re: 1996 Sidekick half-cab ARB lockers AWESOME OFF-ROAD MACHINE
« Reply #1 on: June 24, 2019, 12:32:44 PM »
More photos can be see on craigslist "Florida, Space Coast"
