Here is some new information for the swap,
or just a trick auto with lower gear 1st and 2nd.
OK the 4L30 trans gears will fit into the 3L30
case, but the shaft, which is part of the gears is too
long, so to make it fit it needs to be shortened and
re-splined, now you got some lower gears for offroading
a better low 1 and 2 with the same 1:1 third, cool huh.
Now here is the flip side, the 4L30 trans that comes from a
Diesel Isuzu trooper is an all hydraulic valve body, and only
needs 1 wire input from a throttle position sensor, which all
SideKicks with autos have, so if the T-case will bolt on the the
4L30 this would be a trick 4 speed auto conversion, cool again.
Some more info to think about, now what
