CB Radio Installation
  • 45 Replies
  • 7707 Views
Offline hcgalvin
  • 1695
    • Granite Path
Re: CB Radio Installation
« Reply #15 on: December 26, 2003, 03:45:28 AM »
OK.. here's a shot of my radios. (They are kinda fuzzy...and my truck is kinda dirty... lol) Sorry it took a while... holiday season! :)
I have a Uniden Beartracker 7 Scanner under the steering wheel on the driver's side attached with one already there under dash screw, and then screwed in with another screw (I think it was a self tapper? lol) to make it two. The scanner is about the size of a small radio like a cobra or radiosmack), so this might be a good comparison:
I also have a Uniden PC78 Mounted in the same fashion on the passenger side under the dash. This one just used two of the original dash screws that were already there. Easy install.
Here's a shot of all three. The Icom 2720 (Amateur) has a removeable face that we attached to the front of the ashtray.
Hope maybe this helps....?
Heather
Heather Galvin
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #16 on: December 26, 2003, 04:15:24 AM »
Nice set up!  :o
« Reply #17 on: December 26, 2003, 05:52:40 AM »
I only use my CB when I'm wheeling, it sits on top of the dashboard on Velcro pads. The power lead has a cigarette lighter plug on it (fused). That way I can remove it when its not in use.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #18 on: December 26, 2003, 09:27:44 AM »
Because of room I got a Cobra with all the stuff set into the hand set.  It attaches to a little box I mounted in the dash.
I was worryed about how well it would work but was supprised at how well it does work.
It actually works better that some of my friends larger more expensive models.  I do have a high grade attenna and is tuned proporly.
32 MTR's Warn 8000i
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #19 on: December 26, 2003, 10:30:39 AM »
I got the antenna installed today and I'll decide tomorrow where the CB will go and post some pics. Heather, as usual, I'm impressed. :o
TN_T
« Reply #20 on: December 26, 2003, 02:31:09 PM »
I used the Velcro on the dash, and found the radio
comes loose from the rough ride, so I have been
thinking about mounting it in the dash, left of the
steering collum, where I have a bunch of blank
switch knockouts, small Cobra might just fit there.
Offline TN_Tracker
  • 1113
« Reply #21 on: December 27, 2003, 06:00:06 AM »
Here's how I did it:
Made a bracket to hold the Antenna.
Mounted the CB using one existing screw and only drilled 1 other hole.
Mounted the Mic Clip using an existing screw.
It works great. Thanks for the advice.
TN_T
« Last Edit: December 27, 2003, 06:06:25 AM by TN_Tracker »
Offline Kreg
  • 795
    • Island 4x4
« Reply #22 on: December 28, 2003, 02:34:58 PM »
Heres some Pics of ksa421's CB.
(sorry for the delay KSA, just been busy the last few days)
Offline ksa421
  • 382
« Reply #23 on: December 28, 2003, 04:28:52 PM »
Thanks  Kreg :D ;D :D No worries, I appreciate the help. Have a great New Years.
« Last Edit: December 28, 2003, 04:29:44 PM by ksa421 »
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #24 on: December 29, 2003, 11:02:04 AM »
 DOESN'T THE WEIGHT OF THAT SPARE PUT A BEATING ON YOUR REAR DOOR
Offline Natebert
  • 1098
« Reply #25 on: December 29, 2003, 02:17:13 PM »
TN_T
Looks great!
Offline TN_Tracker
  • 1113
« Reply #26 on: December 29, 2003, 02:39:21 PM »
Thanks Nate. What Brand of CB Antenna are you using?
Offline ksa421
  • 382
« Reply #27 on: December 29, 2003, 07:08:55 PM »
This may sound bad, but I havent really paid that much attention. :-[ I have thought of getting the Clamini rear tire holder/bumper. Have you or anyone had a problem before? I guess I should check, but I dont think it has beat it up too much if it has. Thanks for brining it up though, I will have to check it out.
 Jacob
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #28 on: December 29, 2003, 08:26:13 PM »
Radioschmack 102' on the back or I'll sometimes switch it to the Wilson fiberglass on the front fender which is hooked up to the scanner normally... if I get tired of the 102.
Heather
Heather Galvin
« Reply #29 on: December 29, 2003, 09:20:16 PM »
 Jacob
Jacob,
I have been running with a 33x12.50 hanging on my stock mount for years without trouble. Just remove the tire occasionally and make sure it is not denting or cracking around the mount.
