Clunk in my drivetrain...
  • 20 Replies
  • 3585 Views
Offline Kreg
  • 795
    • Island 4x4
Re: Clunk in my drivetrain...
« Reply #15 on: January 10, 2004, 12:35:51 PM »
I had them on there when I only had the suspension lift installed.
The only problem was that the front of the rear fender came very close to the tire.  And I imagine if I tried to flex the sespension it would have jammed right in.
If you are willing to trim your fenders, the 31's would fit pretty good with a 3" suspension lift.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #16 on: January 10, 2004, 12:37:55 PM »
Then with a little trim job you can go with 35's!!
32 MTR's Warn 8000i
SpinalTap
« Reply #17 on: January 10, 2004, 12:39:14 PM »
Its not much more for the body lift as well so I'd likely go for the combo...then if I chose to I could go up to 33's without much hassle...thanks for the info
Offline jagular7
  • 1026
  • Jagular7
« Reply #18 on: January 10, 2004, 01:07:22 PM »
I took my Traker for a ride once without the rear drive shaft.  (Ducked taped a cup to the output so I wouldn't sling oil every where.)
What a ride!  It's realy squrraly!!  Be careful if you try it.
In my 92 Bronco, on it's first trip with the lift several years ago, I broke the double cardon joint in the rear ds. I had to drive 2 hours home in 4-wheel front wheel drive. That's why I mentioned about the sharp slow speed turns.
Lenexa, KS
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #19 on: January 10, 2004, 01:11:20 PM »
I couldn't go very far in just front wheel drive.  Maby it had something to do with me not having a sway bar?  I was all over the road.
32 MTR's Warn 8000i
Offline jagular7
  • 1026
  • Jagular7
« Reply #20 on: January 10, 2004, 01:18:44 PM »
Me too. Plus the Bronco weighs some 6k#'s. 6" suspension +2" bl., on 35's. Front axle is TTB (twin traction beam) so it's a mix of straight axle and IFS.
Lenexa, KS
