Suzuki V-6
  • 22 Replies
  • 4736 Views
Offline explosivo
  • 3157
Re: Suzuki V-6
« Reply #15 on: July 05, 2005, 07:07:01 AM »
FWIW
    Think about the 2.0l Suzuki L-4
- Easier to install (bolts to trans)
- Tons lighter (75lbs is alot in a 2000lb vehicle)
- 127-135hp stock....let alone playing with it.
    I would almost bet that a 2.0L would out do the 4.0L Ford (lighter, getting only 15-20hp less) based on power to weight.
Zag
The Ford's gonna outdo it in torque, which is going to make more of a difference offroad.
omghi2.us[/url]
Offline zaggy
  • 1134
Re: Suzuki V-6
« Reply #16 on: July 05, 2005, 07:15:53 AM »
I won't argue that torque is what you need off road, but the lighter weight and good t/c gears are goona get you the best balance of worlds....
- Easier swap
- Similar power
- Less weight
- All Suzuki
Zag
Offline zukibrother
  • 10
Re: Suzuki V-6
« Reply #17 on: July 05, 2005, 07:19:07 AM »
- Easier swap
- Similar power
- Less weight
- All Suzuki
Zag
how about cost?  i am all for keeping suzuki, but i don't have lots of money to spend.
Offline explosivo
  • 3157
Re: Suzuki V-6
« Reply #18 on: July 05, 2005, 07:35:36 AM »
If it bolts right up to a 'kick trans, cost would be pretty low, considering all you'd need is an adapter, motor mounts, and a wiring harness/computer to stick it in a Sammy. Assuming that the engine itself isn't too much from a salvage yard.
omghi2.us[/url]
Offline zaggy
  • 1134
Re: Suzuki V-6
« Reply #19 on: July 05, 2005, 07:47:08 AM »
The swap isn't bad, I'm building the parts right now to do my wifes 4dr
- Custom flywheel (1.6 modified to fit 2.0L, done)
- Custom motor mounts (still working on it)
- Wiring harness mods (still working on it)
I'm going to use everything else from the 1.6 thats already in the 4dr (Rad etc)
    I've got a thread going on it I just haven't had time to do much more lately. Basically I'm getting all the parts ready and bugs worked out before I take her 4dr off the road to do the install.
Zag
Offline mbmarkyb
  • 461
    • UK Vitara
Re: Suzuki V-6
« Reply #20 on: July 07, 2005, 01:30:57 AM »
the v6 has that nice sound , the install looks good.
if the 2.0l bolts up to the kick gearbox thats handy,  i take it you use the 1.6 fly wheel and clutch ?
Markyb (UK)
UK Vitara JLX SE
Offline zaggy
  • 1134
Re: Suzuki V-6
« Reply #21 on: July 07, 2005, 02:16:22 AM »
     I will use the 1.6 flywheel modified, centerforce or similar clutch for the 1.6
Zag
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: Suzuki V-6
« Reply #22 on: July 07, 2005, 12:18:18 PM »
the v6 has that nice sound.
Yes it does ;), I would luv to here what a flow master would sound like on mine.
