1.6 in a sammy
  • 9 Replies
  • 2361 Views
Offline roeman
  • 62
  • 1994 sammy!
1.6 in a sammy
« on: May 16, 2005, 01:44:16 AM »
Hi, i am considering putting a 1.6 in my sammy, (8v)
What is the performance like any one have a 0-60 time?
How easy is it to do? do you just but the adaptor plates?  (i have limited mecheanical know how)
cheers guys  :)
1994 sammy
1995 Vitara 16v
Offline Ddog87
  • 109
Re: 1.6 in a sammy
« Reply #1 on: May 16, 2005, 04:08:58 AM »
Friend of mine just did this swap. He used trail toughs kit and it was simple. We wnet to the dunes this weekend and there wasn't hardly a hill he could not climb. He has wrangler lift with 33" tires. I have a sidekick and he stayed right with me
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: 1.6 in a sammy
« Reply #2 on: May 16, 2005, 04:26:06 AM »
Too bad there's no "search" button on this board
For what it's worth:
http://www.nitromax.nl/SAMENGINESWAP.HTM
« Last Edit: May 16, 2005, 04:26:32 AM by nitromax »
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline Cwkick
  • 888
Re: 1.6 in a sammy
« Reply #3 on: May 16, 2005, 05:09:15 AM »
There is a search button at the top of the page.  Third button over.
Cwkick
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: 1.6 in a sammy
« Reply #4 on: May 16, 2005, 05:14:10 AM »
Sarcasim   ^^^  :)
« Last Edit: May 16, 2005, 05:15:36 AM by jeffsimons »
Offline roeman
  • 62
  • 1994 sammy!
Re: 1.6 in a sammy
« Reply #5 on: May 16, 2005, 05:31:44 AM »
on that webpage you had to weld is this totally nessary can i get away without doing that?
cheers  ;D
1994 sammy
1995 Vitara 16v
Offline Ddog87
  • 109
Re: 1.6 in a sammy
« Reply #6 on: May 16, 2005, 06:06:48 AM »
NO welding on trail toughs kit
Offline nitromax
  • 206
    • NitroMax's Pages
Re: 1.6 in a sammy
« Reply #7 on: May 16, 2005, 06:15:16 AM »
cheers  ;D
Of course there's a way around welding, buy an expensive kit that does exactly the same as the way we did it on my rig ;).
Cost is..................errrrmmm..............a cup of coffee for the guy that welded it and a couple of old bolts ( which again didn't cost a dime actually ).
|removethispart|@ ZuksofHazzard: very sharp ;D
« Last Edit: May 16, 2005, 06:15:42 AM by nitromax »
Offline Ddog87
  • 109
Re: 1.6 in a sammy
« Reply #8 on: May 16, 2005, 06:40:04 AM »
If you don't have a welder or friends there kit is $149. Pretty cheap
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 1.6 in a sammy
« Reply #9 on: May 16, 2005, 10:50:02 AM »
I used the Calmini kit on mine without welding.  Works great!
See this article at izook.com:
http://www.izook.com/tech/samurai/engine/1600swap/tech1600motor.htm
Depending on how you want to set up the aspiration, it gets a bit complicated and expensive.
The ultimate way is to use a adapted engine harness, ECM and 1.6 Fuel Injection system.  Benefits: reliable offroad operation at unusual angles, low maintenance, good fuel economy.  Problems:  rebuilt harnesses can be expensive.
Most of the big aftermarket suppliers offer rebuilt harnesses -- Trail Tough comes to mind...
Another way is to use a 1.3 head with an aggressive cam and a Weber carb (DGAV 3236 is a typical unit).  Sarge at Midwest Performance http://www.performancewebers.com/  has a nice setup that includes a slightly-modified intake that improves operation at unusual angles.  This is what I run.  My head and cam came from a well-known vendor but I cannot vouch for his ability to deliver on his product without severe brow-beating over the phone (no, it isn't Rocky Road...)  Benefits:  simple technology (read NO rats-nest of vaccuum hoses!), no ECM, okay fuel economy,  costs a little less.
If I had the 1.6 WITH the harness and the ECM, I'd get the  harness rebuilt as the cost would be a toss-up but the reliable odd-angle operation would be a big plus!
« Last Edit: May 16, 2005, 10:54:37 AM by ack »
Ack
