Water pump leak
  • 1710 Views
Water pump leak
« on: May 15, 2005, 05:02:31 PM »
I seem to have a leak(coolant) coming from the bottom of my water pump area. I know that if the seal goes it will leak out of the little hole, but my hole is at the top and no water is visable there. Is there a hole at the bottom as well? I can't see under there, even with a mirror and it is driving me nuts.
Tony
Offline Mythose
  • 361
Re: Water pump leak
« Reply #1 on: May 16, 2005, 02:55:23 AM »
Yes there is a hole at the bttom and at the top, replaced mine last week.
Offline Mel Taylor
  • 21
Re: Water pump leak
« Reply #2 on: May 16, 2005, 05:14:44 AM »
Yep, chances are about 99.999% certain that you need to replace the water pump.
Mel
When you hold the shift key down and type 4X4 it comes out $X$. Could anything be more appropriate?
Offline adamd
  • 369
  • sofa king we todd it
Re: Water pump leak
« Reply #3 on: May 16, 2005, 10:38:57 AM »
That's the weep hole, water pump is shot.
'98 kick
3" B/l
30" Mud Kings
Offline Mel Taylor
  • 21
Re: Water pump leak
« Reply #4 on: May 16, 2005, 10:57:10 AM »
I don't know anything about the 1.6 liter engines, but if you are running a 1.3 Sami, this might be a good time to consider changing the timing belt as well (depending on the mileage and/or belt condition).
Mel
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: Water pump leak
« Reply #5 on: May 16, 2005, 11:03:10 AM »
Mel
Yep! Same thing. Replace the belt while your in there.
Re: Water pump leak
« Reply #6 on: May 16, 2005, 12:51:00 PM »
Thanks for the replies guys. BTW its a 16 valve 1.6.
I'm at 200,000 now so the belt is due. I am also going to do the valve seals. It puffs on start up.
Tony
