author=jagular7
If you look real close, you can see, if this is to be static, the front ds is hitting the crossmember......hehe. Ford's with TTB which go to SAS have the very same problem.  So do a custom crossmember, some cut out a section and loop it up over the ds, some even took a pillow block bearing and used that on the strengthened crossmember. I've got a pillow block stock on my X! for the rear ds.  I'll assume that you still have the stock t-case in rather than the OTT3 setup. So then the front ds would interfere with the crossmember even more so since the output will be back farther.
Here is actually a closeup of the crossmember that you saw in that picture:
The front DS is NOT hitting the crossmemer, and never would in this position. This shot is of the front DS in full droop as well.
However, We WILL be going with an OTT Kicker 3 setup, and will have to re-create crossmembers anyways.  So... this won't stay here.
Heather.
Yep, we ARE still working on it, will have some more pictures later....
