tracker/sidekick steering gear box leak
  • 1547 Views
Offline douglas
  • 17
  • I'll keep digging, till I feel something.
« on: February 23, 2004, 01:28:20 PM »
I did the p/s swap to my sammi and everything is working great except for a leak on the output shaft (to the pitman arm).  Any of you guys had this problem?  There is no suzuki part for that seal without buying a whole assembly.  I was told a bearing and drive place could measure the seal and come close.  Could synthetic p/s oil do this?  That's what I put in.  BTW it is a 95 sidekick box I think.
Thanks
Drunk on ego.   Surely thought I could make it right if I hit you one more time.  To help you face the nightmare of your life.
Re: tracker/sidekick steering gear box leak
« Reply #1 on: February 23, 2004, 04:47:47 PM »
synthetic oils seem to find leaks,
change to regular and see if it quits.
Offline speedytang
  • 78
« Reply #2 on: February 23, 2004, 06:30:40 PM »
Drain and put in regular power steering fluid if for nothing else but the leak sealer chemicals they put in it.
Offline douglas
  • 17
« Reply #3 on: February 24, 2004, 12:29:28 AM »
How have you guys drained it?
