Sidekick - ute style back door possible ?
  • 1845 Views
Offline Tyson
« on: May 16, 2005, 04:52:00 AM »
please note, aussie's call a sidekick a "vitara" :D
Hi,
I'm not a technically minded person, but I was wondering is it possible to convert the back door on a 2 door soft top vitara to swing down, instead of swinging to the side to open ?
This would provide lots of good uses, not sure you could keep the spare tire on there.. maybe if you had really strong brackets to hold the door whens its opened.
Anyone ever seen anything like this or have any ideas if it can be done?
I'm not sure if it would be complicated, the only thing I saw in my door was a light for the number plate.
Comments greatly appreciated. ;D
« Last Edit: May 16, 2005, 04:53:31 AM by Tyson »
Offline 92Sidekick4x4
  • 1456
Re: Sidekick - ute style back door possible ?
« Reply #1 on: May 16, 2005, 05:58:59 AM »
i've seen pictures of it done somewhere, not sure wher ei did tho, any others ???
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #2 on: May 16, 2005, 11:40:50 AM »
i've been trying to do this for a few months now, if you can be bothered looking back a few pages there should be a thread.
i had a good look around the wrecking yards, and i havent been able to find a suitable donor tail gate.
i was actually looking at hinges and locking mechanisms, but still, most hinges are welded into the tail gate, and so if you want, you'd have to cut them out of the door.
i will be making a custom door for my vitara, as both sides are not the same, as in the left side, where the lock is, and the right side, where the hinges are.
also, you can, but dont think its a good idea to use the existing vit hinges, as they are not exactly the same.
i will be getting some big-ish trailer door hinges to put on, as i'm looking at making the rear door removable as well.
in the rear door, there is the handle, and lock mechanism, not sure if you still want to use something like this, chances are it'll be way too complex to be worth it. and the lights, meh, this is easy, re-route the wiring to where ever you need.
i will be looking into some trailer latches too, on the outside maybe, and on both sides. like Mr. Bean on his mini maybe.... anyway.
i'm just waiting on some time and money to come around before i start. have a look at the tail gates on the new holden crewmans, they are similar to what i may be using.
and to hold the tailgate up, i'm just gonna use some chain on either side of the door, but maybe both.
as for the spare, i havent carried a spare in my vit for over a year now. touch wood. but if you still want a spare, you'd probably need to get a custom rear bar/bumper made up, so you can attach a swing away tyre rack thing. sorta defeats the purpose of having a drop down tailgate. i just chuck my spare inside, i have no back seat.
later.
also, saw ur post out outerlimits, this should answer it too. outerlimits isnt that great when it comes to vitaras in general, but anythin zook is always good.
cheers
Steve
Offline Tyson
« Reply #3 on: May 16, 2005, 03:55:08 PM »
Thanks! That was a really good long reply. :)
I wanted to do the door with simple mechanisms, so latches and chains sounds like a good idea.
I think it's going to be hard to find a good donor door, not to mention one that fits.
Have you thought about the soft top canopy? I saw a foto on the net at cardomain, where this guy had a 2door soft-top, and he either converted or got another softtop, that made the suzuki more like a truck. It had a deck cover, a wall, and the sunroof.
I'm also thinking of building a shelf type thing in the back, that will conceal / hold the spare wheel at the same time.
I think a Ute style Sidekick would look really cool, but it's not going to be easy.
Offline Tyson
« Reply #4 on: May 16, 2005, 05:03:31 PM »
I found the soft top canopy |removethispart|@ Bestop.
It's a Strapless Bikini + Windjammer + Deck Cover.
I don't like the Deck Cover though, I might get a more flatter one made up.
Offline SiKiD_01
  • 574
« Reply #5 on: May 16, 2005, 10:01:05 PM »
just get one made up to your specs, will be cheaper in the end, providing your not too fussy.
i got mine made up, its a fast back style, also uses original side frames.
theres another thread on here with a pic of my vit, check it out.
