2 new headlights (one dim)
  • 2926 Views
Offline MB
  • 223
« on: February 22, 2004, 08:51:47 AM »
just installed 2 new headlights today in my 89 sami, the pass side was going dim. Well after the new install I find the same thing.... bright driver side and real dim pass side, so dim it may as well be off!
anyone know what up with that? wires are all clean and tight. My head hurts from banging it on the brick wall all day tho  >:(
« Last Edit: February 22, 2004, 08:52:58 AM by MB »
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: 2 new headlights (one dim)
« Reply #1 on: February 22, 2004, 09:16:24 AM »
It sounds like a bad ground somewhere to me. Run a test wire from battery ground (-) to the headlight ground and see if that cures it. Then you'll know for sure if that's your problem.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #2 on: February 22, 2004, 11:49:19 AM »
Dido
32 MTR's Warn 8000i
Offline Crow_Horse
  • 29
« Reply #3 on: February 24, 2004, 11:57:41 AM »
More than likely, it's a blown fuse.  As weird as it sounds, if the fuse is blown, there will be power to the headlight, but only enough to dimly light it....
All Good Medicine,
Crow
Offline Wildweasel
  • 106
  • Git er Done!
    • Wildweasel's world
« Reply #4 on: February 25, 2004, 02:10:08 AM »
Samis have a fuse for each headlight, as Crow stated,
if the fuse blows the bad headlight will find a ground (weakly)
and light up dim. Remember that most of the wiring harness switchs don't supply power they connect grounds.
Glenn
91 geo tracker, Toyota axles, twin tcases,35's too many mods to list.
Offline MB
  • 223
« Reply #5 on: February 25, 2004, 03:37:59 AM »
Going to check into this fuse idea today.
Running the extra ground wire to the headlight from the bat. had no change.
If this don't work i'll just have to live with it.
« Reply #6 on: February 25, 2004, 07:01:13 AM »
ya but then you would have to change your user name to winky   ;)
