Samurai Speedo in Track/Kick Cluster?
  • 14 Replies
  • 2989 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: February 21, 2004, 06:12:02 PM »
Just like the title says, does anyone know if a Samurai Speedo will plug into a sidekick cluster? Or A sidekick speedo in a sammy case?
I was just thinking about this tonight considering we plan on the OTT Kicker 3 setup, and will be ordering it this week. Since the back portion of the Kick case will be coming off (the portion that the speedo attaches to) we will obviously have to use the speedo in the Sammy case.
Anybody know?
Heather
Heather Galvin
Re: Samurai Speedo in Track/Kick Cluster?
« Reply #1 on: February 21, 2004, 06:31:59 PM »
I don't see why you can't just move the cable over to the samurai case, it should just plug right in.  if it is not raining bad I will look at my 4 door and my samurai for ya. Dennis.
« Reply #2 on: February 22, 2004, 12:27:10 PM »
I checked out the dash part they look the same just push on and it clicks tight, the samurai x-fer case part it pushes in after first removing a small bolt on the side, the 4 door I have is too low to get under and it was raining out but you should be able to look at yours easyer and let me know what it looks like and the samurai one plugs in on the drivers side aiming twards the low side of the frame or lower, hope this helps.!
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #3 on: February 22, 2004, 12:51:12 PM »
The plug into the sami case is different. Am I to understand this correctly? The Sami cable plugs into a tracker dash pod? Did you actually plug it in or just guessing. Im very interested in this info also.
Mike
« Reply #4 on: February 22, 2004, 01:19:31 PM »
I was looking at the speedo cable the electrical part is not even close, I could try pluging my samurai seedo cable into my kick if ya want? may be they want to run a remote speedo between the seats just to go to moab ;D
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #5 on: February 22, 2004, 01:34:08 PM »
The electrical part isnt inportant to me, Just the cable. Do you have a kick pod already out and a Sami cable handy?  ::)
Mike
« Last Edit: February 22, 2004, 01:36:40 PM by Mikerpm4x4 »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #6 on: February 22, 2004, 03:37:24 PM »
OT, But did you get the info you needed for the SOS Lucky 13?
Sorry man, I never needed a lucky 13... Maybe someone else?
Heather
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: February 22, 2004, 03:38:28 PM »
Hey guys, it would be really neat if anyone had information on this! :) I want to make sure if one or the other will plug into one or the other, and that it will work correctly!!
I really appreciate all your effort!
Heather
Heather Galvin
Offline idaholwb
  • 772
« Reply #8 on: February 22, 2004, 03:59:12 PM »
 Heather, remember my black sammy? It had a kick trans & t-case with the stock sammy instrument cluster with a kick speedo cable. The only question about this application is, my kick speedo cable was out of a 90 kick, don't know if the 95 is different or not. Anyone know if there is a difference with different years of kick?
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #9 on: February 22, 2004, 05:02:06 PM »
I have an 88 samurai non tach speedo laying around I could try out in the 94 kick 4 door if ya want? I do not have the cluster for the 4 door it is a drive train doner. (or soon will be). ;D
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: February 25, 2004, 04:22:12 AM »
Hey mrfuelish..
did you try this out yet?
I am still interested in knowing, as my kicker 3 will probably be back to me the end of next week.
Thanks again!
Heather
« Last Edit: February 25, 2004, 04:22:25 AM by hcgalvin »
Heather Galvin
« Reply #11 on: February 25, 2004, 06:51:24 AM »
I will go out side in a little while and check for you, (sorry I forgot) is it snowing in idaho yet? it's getting with it here.
« Reply #12 on: February 25, 2004, 07:19:58 AM »
Ok, just got back in, it worked great, I pluged my 88 samurai cluster into the 94 4 door speedo cable and it looks like it was made for it, fit great and even came back off the way it should, hope this helps.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #13 on: February 25, 2004, 07:27:22 AM »
Thanks!
Heather Galvin
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #14 on: February 25, 2004, 11:41:17 AM »
 8) Thanks, Now I just have to find a sami cable.
Mike
