Sidekick brake system issues. (FIXED!)
  • 31 Replies
  • 10270 Views
95XL7
Re: Sidekick brake system issues. (FIXED!)
« Reply #30 on: August 29, 2005, 04:23:10 AM »
I've been having some of the same problems on my tracker since i disconnected the ABS.
I removed the ABS log under the MC and re-connected the lines. Sometimes the pedal is fine othertimes it's soft or the rear brakes make a clicking sound when braking. What i plan on doing is comparing the diagrams for ABS and non-ABS and setting it up like the non system
and re-bleeding. If you look at the lines coming off the master,they come off in different locations for abs and non-abs.
« Reply #31 on: August 29, 2005, 09:48:10 AM »
Total clicks with no resistance is around 20, so 10 is only half-way up...
I've just checked my FSM, it states 7-9 clicks with a 44lb pull. I would guess that 7 clicks is when the handbrake adjusters have just ratchetted over and 9 is when they are about to.
