Tracker ground clearance sag?
  • 31 Replies
  • 9217 Views
Offline z28jeff
  • 33
Re: Tracker ground clearance sag?
« Reply #30 on: April 22, 2019, 05:44:25 AM »
What vehicle did you get after the Tracker?
Why another Tracker of course!  ;)
I'm building this one for Overland duty, so some things are getting done different than the white one. For example, I'm still using the same spacer lift and KYB shocks/struts, but I'm adding airlift air bags to the rear springs to help out when it's loaded down with camping gear. I'm also gearing down to 5.13's since this Tracker has the 2.0 4cyl. Here's some recent shots of it still on stock suspension with 225/75/15's. The Yakima RTT just arrived last week.
2003 Tracker 4 door 2.0 auto
2013 Suzuki Kizashi SLS AWD
2002 Corvette Z06
Offline CoastMtns
  • 18
« Reply #31 on: April 30, 2019, 07:27:31 PM »
That is one stylin' set up Jeff - of course you got another Tracker! That's rad, big adventures for sure on summer's horizon.
You would feel right at home here on the Sunshine Coast, BC. There are so many Trackers + older Sidekicks around.They are almost the the official used ride in our community  :D
