complications
  • 17 Replies
  • 3237 Views
Offline weaver
  • 145
  • all i want to do is make my suzuki happy
complications
« on: May 17, 2005, 07:09:44 AM »
so as i read and everybody very nicely responds to all  of my and others questions,, i start to notice that when you do a lift, you have to address the bumpers, the gastank then needs lifted which means you cut off the vapor separaters, then you may need catback exhaust with K|removethispart|@N filters, etc ,, etc...           im not trying to sound like im crying,,,,,,,,,,            its just i dont know exactly what im doing and what im getting into......
but i dont want to keep it stock because i love your photos
so confused............................. ;D
98 2door clothtop stocker
2" BodyLift, 15x7's, 235's,
soon- filter, exhaust, etc. etc. etc. coil spacers, etc. etc. & more-----i think
Offline bus_driver
  • 479
  • the voices tell me different things
Re: complications
« Reply #1 on: May 17, 2005, 07:26:20 AM »
well I was recently a newbie and I was like wow to everything also, the first big question is what do you want to do to with your rig? show mud rock all and what is it. form there everybody has input . MILD to WILD
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Mythose
  • 361
Re: complications
« Reply #2 on: May 17, 2005, 07:47:40 AM »
Know what you mean, but people on here lik zig / wild and others have som narly trail rigs,  dont know if they drive them every day, but presume they do not. For me i want a bit more agressive wheels, snorkel, and a lift so i dont drownd it out, i like crossing mudholes - rivers to get back to that perfect fishing hole, but i also want to keep close to stock mileage.  Cause i drive it every day.
anyway what do you want out of the rig, they are perfectly good off road stock, just not as good as they could be.
bus_driver is right
Offline Natebert
  • 1098
Re: complications
« Reply #3 on: May 17, 2005, 07:51:39 AM »
This is Heathers daily driver.
« Last Edit: May 17, 2005, 07:52:41 AM by natebert »
Offline Mythose
  • 361
Re: complications
« Reply #4 on: May 17, 2005, 08:03:26 AM »
what type of mileage do you get, and it looks really nice
Offline bus_driver
  • 479
Re: complications
« Reply #5 on: May 17, 2005, 08:11:52 AM »
i love Heathers daily driver .....throw the kids in the door take a running leap into the seat and hope you did not forget anything
« Last Edit: May 17, 2005, 08:12:28 AM by bus_driver »
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Natebert
  • 1098
Re: complications
« Reply #6 on: May 17, 2005, 08:18:23 AM »
Depends on how agressively it's driven.
75-65mph on the highway, it gets about 18mpg on average.
55-45 it gets almost 20mpg.
around town ~16mpg
Offline Natebert
  • 1098
Re: complications
« Reply #7 on: May 17, 2005, 08:19:01 AM »
You should see my 8 year old daughter get in this thing.
She climbs up the rim, on the tire, over to the rock sliders and then in the truck.
« Last Edit: May 17, 2005, 08:21:51 AM by natebert »
Offline chet
  • 556
  • Zuki time!
Re: complications
« Reply #8 on: May 17, 2005, 08:20:52 AM »
you have an 89 year old daughter!  :o I'm not suprised she has problems getting in! Don't break a hip!  ;D
Offline Natebert
  • 1098
Re: complications
« Reply #9 on: May 17, 2005, 08:22:44 AM »
Whoops.  I was thinking 8 going on 9.  (her birthday is coming pretty quick)  Wierd how fingers can type what the brain is thinking without really thinking about it.
~Nate
Offline Mythose
  • 361
Re: complications
« Reply #10 on: May 17, 2005, 09:39:29 AM »
Yeah my wife drives the 84 Sub as a daily driver,  she only has to drive around in town, and it is funny to watch our 4year old get into the thing the dorjams are around 39" off of the ground i mean she can almost walk clean under the truck, but she has found a way to climb in all by her self uses the seatbelt  as rope.  ;D. our cam is broke but i will get pics up here.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: complications
« Reply #11 on: May 17, 2005, 09:41:43 AM »
Yep.  Lifts is difficult...
As one poster pointed out, it kind of depends on what your goal is.
Body lifting addresses the problem of installing larger tires, yet does not completely address body/frame clearances.  You still have an unmodified suspension that is expecting normal sized tires and does not deal with rubbing caused by reduced steering clearances.  The unmodified suspension also has the same flex travel.
There are a number of articles describing body lifts on the Internet on the subject.
Information can often be found at vendor sites (Calmini.com comes to mind) and at places like here at Zukiworld.com's article archive, Izook.com Tech sections and Offroad.com tech sections.  I am sure that there other places that I have missed.
My familiarity for the TracKick is limited as I am just getting into it from the Samurai side (which is different!).
What I know is this:
There are a number of components that cross from the frame to the body besides the actual mounts themselves that are affected depending on the amount of body lift that you are applying.  Brake lines, fuel lines (both to the engine and the filler cap), electrical and transmission/transfer case.  And, if you have an automatic transmission, it's controls are handled differently than a manual transmission -- cable instead of shifter.
Less than two inches of body lift, fewer of the above need radical modification. Greater than 2 inches more mods.
Good luck!
Ack
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: complications
« Reply #12 on: May 17, 2005, 09:42:19 AM »
Wait...
They let you REPRODUCE?   :o :o :o :o :o
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Natebert
  • 1098
Re: complications
« Reply #13 on: May 17, 2005, 11:12:22 AM »
Wait...
Yah, can you believe it!
Offline 92Sidekick4x4
  • 1456
Re: complications
« Reply #14 on: May 17, 2005, 01:52:34 PM »
I had no idea u guys had kid's, in all your pictures that ive seen on your website and that youve posted up ive never seen a kid with you in the truck or anything :D ;D
