I have a Harbor Freight winch. 8000 lbs and costs under $300 on sale. It looks just like a Mile Marker 8000. I have only had to use it once to pull the tracker out of a high side(all four wheels off the ground), but I used it about twenty times to pull down oak trees after the hurricanes. One tree was a little too big and picked the tracker front wheels off of the ground. I also put a harbor freight 2000lb winch on the rear(it was only $49). I figure I can pull about a hundred pounds max with my body, so 2000lbs is a lot better. Also good for pulling something on a trailer. I fabbed up my own bumpers and winch mounts and everything is welded. The winches themselves are through bolted and then tack welded to discourage theft.
Mike
