Crankshaft Pulley 199? sidekick
  • 2563 Views
Offline sidekickyc
  • 137
« on: January 03, 2018, 06:57:05 PM »
It seem I have to replace the Crankshaft on Daughters  1.6 sidekick```
I installed a engine form a~ I thought 1994 sidekick~ wife says 1995 sidekick~ in daughter's 1997 sidekick```
Here's my question: Is there a difference in the Crankshaft pulleys? I want to use the same size belts```
note: when I changed the engine I had to put the old Oil Pan one to allow for the crankshaft sensor```
would both 1994 and 1995 1.6 L engines not have the chankshaft Sensor???
So the Pulleys are the same 1994 - 1997
Thanks
Richard
« Last Edit: January 04, 2018, 02:09:14 PM by sidekickyc »
Offline sidekickyc
  • 137
Re: Crankshaft Pulley 199? sidekick
« Reply #1 on: January 03, 2018, 10:19:47 PM »
Hi if you can help with this~ well ~ this is the thread to do it on```
  • 4331
« Reply #2 on: January 04, 2018, 04:52:13 AM »
I could be wrong on this, but I believe the crankshafts on all the G16 engines are the same - I'll check the part numbers later and confirm.  The crank position sensor reads the lower (crankshaft) timing pulley, so the pulleys are different between the 8 & 16 valve engines - the 8V engines don't have the crank sensor, the 16V engines do.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
  • 4331
« Reply #3 on: January 04, 2018, 06:21:36 AM »
The same part number crankshaft was used from 92~98 - but the pulley numbers are all different.
Offline sidekickyc
  • 137
« Reply #4 on: January 04, 2018, 02:05:54 PM »
Greetings fordem~ thanks for coming by~ two thing:
1. RE: the Crankshaft Pulley~ are they the same```
2. The engine~ when I got the engine~ it had no Sensor~ had to change the oil pan to allow for the sensor~ I remember it being said ~it was 1994 wife says 1995```
So the Pulleys are are the same ~ between 1994 and 1997 put the engine in ~ 1997 sidekick```
Richard
« Last Edit: January 04, 2018, 02:11:08 PM by sidekickyc »
  • 4331
« Reply #5 on: January 04, 2018, 04:46:25 PM »
First - which pulley are we talking about - the timing belt or the accessory drive pulleys?
Second - if the crankshafts are the same, and the crankshaft is what you're swapping - then doesn't it just become a matter of reusing the original pulleys?
Offline sidekickyc
  • 137
« Reply #6 on: January 07, 2018, 01:10:03 PM »
Sorry I've been sick as a dog~weak as a cat```
I was talking about the Crankshaft pulley~ but re reading your post~ I see the pulleys are different``` Thank you~ that's good info```
Was about to install the pulley that was on the engine we pulled~ to install this one~ when~ I'll be right back~ the girls are calling```
Offline sidekickyc
  • 137
« Reply #7 on: January 07, 2018, 03:06:23 PM »
So~ having removed the belts~ we~ youngest daughter and I examined the crankshaft pulley~ it looked to the eye to be good``` the land we not sharp and worn```
In early inspection to check for pulleys out of alignment~ while there was no misalignment of the pullies~ the belt seemed to ride hard against the engine side of the Crankshaft pulley~ even ride deeper on the side closed to the engine while higher toward the out radiator side~ this is the Alternator belt I'm talking of```
We found~ piece of old belt  1/2" long ~ in the outer groove```
Youngest daughter~ with her buck knife and a small wire brush removed that as well as crud until she could see the bottom of the groove```
We reinstalled the belts~ started the engine and belt rode nicely centered on the pulley```
I'm looking to see this as a fix~ I will renew the belt ``` but```
Thanks for the information~ re different pulleys~ same Crank```
Richard
« Last Edit: January 07, 2018, 03:08:46 PM by sidekickyc »
