Vitara handling issues
  • 2645 Views
Offline Phase change
  • 199
« on: December 18, 2017, 05:49:08 PM »
Okay I’m sorting out my 2003 tracker and I’m womdering if anyone can help with some handling issues.  I’ve lifted it 2” with a coil spacer kit and put new shocks on back.  I ran without sway bar for a while and decided it had too much roll so I wrestled the sway bar back on.  This wasn’t easy but I managed to do it.  That improved things a lot but it still has a bit of initial lean on corners, then it takes a set and holds it fine but I’d like to get the initial turn feel to be more planted.  I don’t want to ruin the off road prowess in the process but ?
SO, the things I’m tossing around in my head are
1 wheel spacers
2 wider wheels with same tires
3 wider wheels with different tires
4 ?
The wheels are stock tracker alloys. Are they 6.5” or 7” wide?  The tires are 235/75-15 Goodyear wrangler AT.
2003 Suzuki tracker 4d 5sp 2.0 “piglet”
Deleted air 4wd system, Manual hubs, 2” lift, 235/75,
Old ride: 1997 X90 “jellybean” best lil car I’ve ever had
  • 4320
  • 167
Re: Vitara handling issues
« Reply #1 on: December 19, 2017, 04:54:12 AM »
You've run into the reason I don't like coil spacer lifts - a higher center of gravity with the same spring rate will always result in increased roll.
If the problem is body roll, which I suspect it is, none of the proposed changes will have any impact - you could try stiffer springs or a stiffer sway bar.
« Last Edit: December 23, 2017, 05:49:19 PM by fordem »
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline WVzuk
  • 181
« Reply #2 on: December 19, 2017, 05:53:07 AM »
The Zukination 3" springs made my Sidekick handle a lot better than with stocks springs and spacers.
1994 4dr Sidekick: 3inch Zukination lift, 30x9.50 mud tires, snorkel, ARB rear locker, homemade bumpers
  • 199
« Reply #3 on: December 19, 2017, 08:32:34 AM »
Yeah that might be the case.  I’ve not had that problem before with spacers though, my old Suzuki was fine with them.  Maybe 2”is too much lift
Offline WVzuk
  • 181
« Reply #4 on: December 19, 2017, 11:01:02 AM »
Its a mild amount of lift but I think maybe the method makes the handling off.  I know its expensive but I bet some 8" wheels and solid springs would transform the handling. Look into full spring options vs the spacers and I think it will improve.
