Finished my switch board....
  • 13 Replies
  • 2044 Views
Offline wolf66
  • 193
« on: May 17, 2005, 12:11:32 PM »
Finished my switch panel today, hood rally lights, rack rally lights, spare, left bilge pump, right bilge pump and engine fan. (well it has two more screws on the right side to be put in...)
« Last Edit: May 17, 2005, 12:12:33 PM by wolf66 »
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline Natebert
  • 1098
Re: Finished my switch board....
« Reply #1 on: May 17, 2005, 12:18:41 PM »
That looks GREAT!
Was that a newly purchased board, or was it out of some existing boat application?
~Nate
Offline wolf66
  • 193
« Reply #2 on: May 17, 2005, 12:31:04 PM »
West Marine $39
generic 6 switch panel w/ 15a fuses for each switch..
Had to cut some of the right side off. a inch or two of the top mounting panel..
Offline SnoFalls
  • 1358
« Reply #3 on: May 17, 2005, 12:44:29 PM »
bilge pump is my favorite  ;D  .. looks good
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #4 on: May 17, 2005, 04:13:37 PM »
It's for those deep water crossings ;D
Mean Green Wheeling Machine
Offline wolf66
  • 193
« Reply #5 on: May 18, 2005, 12:30:11 AM »
Yes, yes it is.....
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #6 on: May 18, 2005, 12:44:45 AM »
   Lets see some pics of the bilge pump ;D
      200 posts ::)
At Lakeview Motorsports, were wasting your time already!
Offline Mythose
  • 361
« Reply #7 on: May 18, 2005, 01:46:35 AM »
NICE do the pumps actualy keep the inside dry or just dryer?
if they do work give me some specs on the types of pumps you are running.
Offline wolf66
  • 193
« Reply #8 on: May 18, 2005, 05:57:27 AM »
because of the tranny hump you really need 1 on each side, I got 2-500gal per hr bilge pumps at Walmart |removethispart|@9.99 each, thats 20 gal per min total.
My X stays pretty dry if i make it across with no problems, its when I get stuck and have to get out and hook up the winch that the water builds up, last time it got high enough to flow over the hump and got the top of my seat wet.....
The bilge pumps should keep it down to a inch or two, then i can just open up my drain plugs when i get out...
« Last Edit: May 18, 2005, 05:57:47 AM by wolf66 »
Offline Mythose
  • 361
« Reply #9 on: May 18, 2005, 06:11:27 AM »
YES,  Does the X float with the biget tires? just curious
I made a buggie and welded everythig on the botom and made the strut mounts connect to the outside of the weld and put hydrolic motors for the wheels with about a 40hp hydrolic pulm and if floated but that was kinda the point.
Offline Natebert
  • 1098
« Reply #10 on: May 18, 2005, 06:37:01 AM »
Hows about bilge pumps for your seats?
For those arse puckering moments!
Offline Mythose
  • 361
« Reply #11 on: May 18, 2005, 06:49:35 AM »
ROTFLMAO,
Offline takai
  • 907
« Reply #12 on: May 18, 2005, 07:31:42 AM »
Yes, yes it is.....
In the event of a water landing your seat will not act as a flotation device.  ;D
'Cause, I am to misbehave.
Offline 1bigtracker
  • 3409
« Reply #13 on: May 18, 2005, 08:12:08 AM »
some people have all the good ideas.
i don't plan on staying in that water long enough for it to reach the seat!   lol
stu
  ÂÂÂÂÂÂÂ
