Wheel stuck
  • 1476 Views
Offline Beagler
  • 14
Wheel stuck
« on: May 06, 2017, 04:04:34 PM »
I have a 89 tracker that I can't get the front wheel off of. It has the alloy wheels and it is stuck. I have jacked it up and took the lug nots off and beat the crap out of it with a shop hammer and still no worky. Any ideas?
Offline Beagler
  • 14
Re: Wheel stuck
« Reply #1 on: May 18, 2017, 04:42:36 PM »
 Anyone else ever have this problem?
Offline beagle..t
  • 1239
  • 16
Re: Wheel stuck
« Reply #2 on: May 18, 2017, 07:55:41 PM »
nope ... if they are stuck I just kick the top and they fall off
  • 4320
  • 167
Re: Wheel stuck
« Reply #3 on: May 19, 2017, 07:49:21 AM »
I've had OEM steel wheel stick (on a different model Suzuki)  - the fit around the centre bore was so close that the slightest bit of corrosion would cause it to stick - a good kick would usually free it.
Try threading a length of chain through the spokes - if it can pass - and then loop the ends together and around a sledge and whack the chain - it should yank the wheel loose.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
