SUZUKI SAMARI CLUTCH CHANGE
  • 1344 Views
Offline JAMES44
  • 46
« on: April 01, 2017, 02:42:09 AM »
   NEED TO REPLACE CLUTCH ....IS IT EASIER TO REMOVE THE ENGINE TO DO THIS  ???????
        JIM
Offline Zelgin
  • 50
Re: SUZUKI SAMARI CLUTCH CHANGE
« Reply #1 on: April 01, 2017, 06:35:08 AM »
I would say no.  For me, it's been far easier to remove the transmission, instead.  If the transmission has never been removed, with the engine still installed, you'll need to put a small notch in the frame cross member, to clear the  tail housing on the transmission.  The notch will give just enough room to pull the transmission back far enough, for the input shaft to clear the pressure plate.  I think a search will give you a picture of how big a notch you need.  A small "V" cut in the cross member flange metal is all you need.
