Gears,  vitara, Gv and xl-7???
  • 1811 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: March 14, 2004, 03:10:34 AM »
Ok in the T.S.B article in zukiworld of march, they explain the way to make the vitara, gv and xl-7 better. Ok!
But why they said this:
WARNING: If you are going to do this, make sure you do BOTH the front and the rear gears at the same time. If you do the rear first, and you're coming home one day and accidentally engage the 4X4. Well, guess what? You'll be leaving your drivetrain behind you on the floor.
My question is what gears ratio are in the vitara, gv and xl-7 if it's different to 5.12:1???
Manual and auto are different or the same???
And i will buy an 2000 vitara 2 doors manual, they have abs???(i wish not)
Thanx
Fredo
« Last Edit: March 14, 2004, 10:08:44 AM by Fredo »
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline idaholwb
  • 772
Re: Gears, Gears and Gears!
« Reply #1 on: March 14, 2004, 05:46:55 AM »
 I've heard of 4.30 and 4.88 being the gears in the GV. I'm not sure with the 4 cyl trucks.
97 Sport
265/70-16s
2" lift
2.0 swap
95XL7
Re: Gears,  vitara, Gv and xl-7???
« Reply #2 on: March 14, 2004, 10:44:21 AM »
On the front page of ZukiWorld check the tech specs section,their listed there. ;)
Offline Fredo
  • 416
« Reply #3 on: March 14, 2004, 01:20:02 PM »
Thank you very much!
2 doors manual : 4.875:1
2 doors auto: 5.125:1
Grand vitara manual:4.3:1
GV auto: 4.875:1
XL-7 manual: 4.3:1
XL-7 auto: 5.125:1
Manual R&p are always higher than auto????
It's not suposed to be manual lower than auto, like kick manual 5.125:1 and auto 4.625:1???
Fredo
« Last Edit: March 14, 2004, 10:22:14 PM by Fredo »
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #4 on: March 17, 2004, 12:34:01 AM »
GV auto: 4.875:1
XL-7 manual: 4.3:1
XL-7 auto: 5.125:1
Fredo
There is not hard and fast fule about R&P ratios.  They all depend on the output from the transmission.
While the kicks used to have higher ratios in manuals, the GVs are just the opposite.  The trannys changed.
The XL7 uses a different rear pig, so you can not swap gears on an XL7.
But a manual GV (4.30) can benefit greatly by using Kick manual (5.12) gears when running larger tires.
Yankee Tim
