Project Zuk 3.0 (rows of seats) - 2003 XL7
  • 82 Replies
  • 29691 Views
Offline olija
  • 770
    • Check out my cardomain
« on: February 15, 2017, 08:35:10 PM »
Put plates on the rig for the summer and took it out for the first time this year with my wife and little guy on a short easy trail close to home. He sure loved all the bumping around.
The OME springs make all the difference in the front.Worth every penny. Now I am casually searching for some rear springs that will work, or else just bite the bullet and get OME rears with a spacer to get the extra height I need. I also still need to clearance the rear fenders and set up some limiting straps to prevent excessive topping out of the front end.
AND when I went to retorque my wheel spacer nuts, a couple of studs had some really buggered threads so I need to replace some studs and maybe try some long, thin tuner nuts instead of the stupid short, fat ones that came with these Ultra wheels that the previous owner put on.I think the problem is caused by the tight fit between the socket and the rim as you are starting the threads and trying to center the rim on the studs at the same time. I'm just glad I'm dealing with this now and not on the side of the road somewhere.
« Last Edit: May 19, 2018, 09:42:21 PM by olija »
Online ebewley
  • 6557
  • 64
Re: Project Zuk 3.0 (rows of seats) - 2003 XL7
« Reply #1 on: February 16, 2017, 06:16:58 AM »
Looking good! Xl7 is definitely the family man's Suzuki.
Anxious to see more.
Eric
« Reply #2 on: February 16, 2017, 11:16:36 AM »
I like the welds on that CV conversion.
Offline beagle..t
  • 1239
  • 16
« Reply #3 on: February 16, 2017, 05:42:46 PM »
looks good glad you got it figured out
Offline olija
  • 770
« Reply #4 on: March 04, 2017, 03:52:53 PM »
Some progress updates: Got the front diff installed without too much unexpected issue. Geoff from Zukination told me the exhaust crossover pipe interferes with the front driveshaft, and sure enough, it did, so I needed to take a drift and hammer and beat a little more of a recess into it than is already there. The other issue is when the front diff is installed, there's only about 1/8" clearance between the bottom-most reinforcing rib and the top of the crossmember. I was told to heat it up with an oxyacetelene torch and massage it for a little extra clearance, but I don't have a torch at the shop I'm working at so I will tackle that once I get it back out on the road.
One thing I found unique about the AE lift compared to others, is that they use a "coil shim" between the spring perch and the factory spring isolator on top of the front coil. The instructions don't include a diagram of how they are supposed to go in, so I took my best guess at it on one side, and found I had no down-travel in the front end when it was all together, so I emailed Geoff and he said I had put the shim in upside down so it was sitting ON the spring perch, not IN the spring perch. Took it apart and flipped the shim, assembled the front end completely, and everything is looking good.
The rear is basically done with the exception of the lower control arm-to-frame bolts. They were seized into the sleeves so I had to cut them out. The hardest part was getting the brake line apart after 14 years but I managed with a little persistence.
Sorry only 1 pic for now.
Offline beagle..t
  • 1239
  • 16
« Reply #5 on: March 04, 2017, 07:36:12 PM »
is the rear trailing arms move your rear axle back? does it require driveshaft spacer?
Offline olija
  • 770
« Reply #6 on: March 04, 2017, 09:45:52 PM »
I quote AE's website concerning their extended rear link kit:
For all you out there that have the Spacer Lift or Spacer Lift/Body Combo and have the major tire contact issue in the rear, we have the solution to your problems!  When using spacers to lift the 99 + Vitara/Tracker, the spacers lift the vehicle but unfortunetely without the associated pan hard drop bracket your rear axle is pushed out of center. Combine this with the Vitara's naturally small wheel wells and short rear links and you end up with major contact between the tires and the wheel wells in the rear during up travel.  The end result being torn up tires and damaged body panels.... To combat this we have developed extended links, both upper and lower, that push the rear axle back eliminating the contact.  Included in this kit is a pan hard drop bracket to recenter your axle and a driveshaft spacer to correct the driveline for its new length.
Complete kit includes upper and lower extended links, pan hard drop bracket, all bushings, sleeves, and hardware needed, plus associated length driveshaft spacer to extend the driveshaft to match the new wheel base.
Minor trimming may be needed on stock rear bumper depending on tire size and amount of spacer lift.
I'm actually a little confused how the wheelbase is supposed to change when only the upper links are longer, so I sent AE another email to see what they say. There is also supposed to be a rear driveshaft spacer and track bar bracket but they said since the XL7 uses a 2-piece rear driveshaft with a steady bearing as opposed to the GV which has a 1-piece with a slip yoke built into the back of the t-case, there is more travel available in the XL7 setup so the spacer is not required. Regarding the track bar, he said they just finished an install on an XL7 at the time I ordered this kit, and when they put it back on the ground and checked the alignment, the rear axle was in perfect alignment without any modifications.
I also forgot to mention at the beginning of this thread...the reason I went with the Aerostar coils in the back was because AE's lift is made for a Tracker/Vit/GV, and there are not enough XL7 out there to justify building separate rear coils for them. Around 2003, some XL7's started using larger diameter coil springs (4.75 OD as opposed to roughly 4"), so the springs from the kit would not fit on the spring perches on my axle.
I still need to install the 2" body lift before my 235/80/17's fit in the wheelwells so it will be a little while before this thing sees some miles yet.
Offline olija
  • 770
« Reply #7 on: April 28, 2017, 10:50:48 PM »
So the verdict on the rear links is that they are longer, just not by a huge amount- just enough to compensate for the lift.
I finished up with the body lift. Was pretty straightforward, just takes a long time to tidy up all the details. I had tried to make my own strut brace mount spacers, but it was easier in the end to just cut the fender holes bigger.
Installed the Balmer Fab front bumper. He shipped it to me raw and with the brackets not welded on just in case there were any differences between my frame and the other Suzuki's he has fit this bumper to. It was a good thing too because the frame is slightly different at the very front. But it all worked out and looks great. Hidden behind the license plate is a 2" reciever.
Also modified the spare tire mount to accomodate a 32" tire.
Offline olija
  • 770
« Reply #8 on: May 24, 2017, 09:44:28 PM »
Sneak preview of what my tire/wheel package is going to be once I get my front end sorted out:
Went for a test drive to Telkwa Pass.
My son pointing out that I shouldn't be trying things like this until I get the big tires on and finish up the sliders!
Offline olija
  • 770
« Reply #9 on: June 06, 2017, 08:51:39 PM »
So if anyone's wondering why I haven't put the larger tires on yet, here's why. I've been trying to sort out some front end issues with my Alter Ego lift kit along with Geoff from Alter Ego. My problem is my front end is only lifted around 1", with the 3" lift springs installed. He says my frame height should be sitting at around 11" with stock tires with the 3" lift and I'm only at 9". My front struts are bottoming out any time I go offroad because with the strut spacers they only have about 3" uptravel. So far we haven't come to a conclusion WHY my XL7 is different than the other ones successfully running the AE 3" lift, but we're going to run a trial on the new A-arms that are part of AE's new 4.5" lift. The A-arms are designed to use the same 3" lift coils that I already have installed, in addition to a modified lower spring seat that gives another 1.5" lift for a total of 4.5". Since mine is sitting almost 2" low, it's probably not going to hurt to add 1.5", plus I gain the benefits of having my front wheels moved forward 1.25", bolt-on replaceable balljoints, and the spring is straight instead of bowed. So here's hoping it all works out, then I can finally run my big tires, get an alignment, and start working on the important stuff like skid plates and rock sliders!
Offline olija
  • 770
« Reply #10 on: June 07, 2017, 07:54:59 PM »
Built a tranny and t-case skid plate today out of aluminum. I used 2" tall, 1/8" thick corrugated trailer flooring and some 3/16" flat aluminum and lots of bolts and washers and nylock nuts to hold it all together. It's nice and light, was super easy to drill, should be strong enough, and won't ever rust. I bolted the flat pieces to the pre-threaded factory holes in the front suspension and t-case crossmembers, then bolted the corrugated pieces onto the flat pieces so the corrugated sits higher than the bottom of the framerails.
Offline olija
  • 770
« Reply #11 on: June 08, 2017, 09:22:00 PM »
Here's a little better photo of the skid plates:
And I put these guys on today:
Offline olija
  • 770
« Reply #12 on: June 19, 2017, 05:39:36 PM »
Got my front end sorted out I think. I initially installed the a-arms with the ball joint mounted to the bottom of the arm for mega clearance, but this gives way too much lift and my struts were topped out permanently. I pulled it apart for the 6th or 7th time and mounted the ball joint on top of the arm (I think this is normal, looking at Calmini's product photo) and also removed the three 1/8" shims from on top of the spring, but this made it sit sort of low in the front so I took it apart again and put 2 shims back in on both sides. With the factory tires I was sitting at 10.25" clearance at the front of the framerail, and 11.5" at the rear, and the suspension looks to have a decent amount of travel in both directions this way. So the next step was to install the new tires. The front ones fit pretty good since the AE arms move the wheel forward, but I removed the mudflaps and will probably need to sledgehammer the back of the front fender still. The rear was a tighter fit; I needed to cut the bumper back about 2" but it was pretty straightforward. I didn't have time to see if the tire contacts the front of the rear wheelwell, I'm hoping not since the tire moves back as it goes up but it will be extremely close.
« Reply #13 on: June 21, 2017, 11:35:48 PM »
Interesting read.  Manual Xl7's are hard too find.
Offline olija
  • 770
« Reply #14 on: June 23, 2017, 10:37:53 PM »
Yes they are...I was looking for one for a few months before I found this one. I had to drive all the way to Vancouver to get it but it was worth it!
Now for some flex test pics:
Front and rear tires are so close to rubbing at full flex it's crazy. I probably have 1/4" between the front of the rear fender and the tire, and there's not much that can be done about that. In the front I think I could give it the sledgehammer treatment at the inboard edge of the plastic liner and it will be good. Those A-arms sure do alot to get the tires away from the firewall...I'm sure if I didn't have them I'd be pulling my hair out trying to stop the rub.
The truck rides really nice, even with the E-rated tires. I've been working on a 2-piece aluminum front skidplate that will go from the front suspension crossmember to a bracket that shares my lower bumper mounting bolt. Got the front half done, just gotta figure out the rear when I get a moment.
