90 Samurai JL EFI runs full rich & full retard
  • 1831 Views
Offline 1raddude
« on: November 20, 2016, 03:25:18 PM »
The Mechanic i took my sammy to told me this and the only code i get is 12 so the ECM thinks all is normal i see there has been 2 caps replaced on the ECM i don't know who or where to have ECM checked or repaired can anyone HELP?
  • 4314
  • 167
Re: 90 Samurai JL EFI runs full rich & full retard
« Reply #1 on: November 20, 2016, 07:30:39 PM »
Why did you take the car to the mechanic?  Do you know how he arrived at that conclusion?  Maybe you need to find a mechanic who is familiar with EFI systems.
A defective coolant temp sensor could cause the ECU to think the engine is always cold and that will cause it to richen the mixture and retard the ignition timing, I believe that ECU also gets a "start" signal from the ignition switch, if that were active when it shouldn't be it could be another cause of both symptoms.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline 1raddude
« Reply #2 on: November 20, 2016, 07:46:35 PM »
i took it to the mechanic because it won't idle,it surges 1200 rpm to 2000 rpm it won't pass emissions test.
Offline memex
  • 18
« Reply #3 on: November 21, 2016, 02:56:29 PM »
Well sounds like a code 12
Check it out
https://www.obd-codes.com/p0012
  • 4314
  • 167
« Reply #4 on: November 21, 2016, 08:24:06 PM »
A 90 Samurai is not OBDII, so OBDII codes do not apply - code 12 in this case means that the ECU is not seeing any faults.
Offline 1raddude
« Reply #5 on: November 21, 2016, 09:39:47 PM »
i got a code 14 to flash by disconnecting coolant sensor but i don't know how to check ignition switch for a start signal after engine is running  any help?
  • 4314
  • 167
« Reply #6 on: November 22, 2016, 06:33:15 AM »
Do not assume that the coolant temperature sensor is good because the ECU does not report a fault - the ECU will only tell you if it is shorted or disconnected - it won't tell you if it's saying cold when the engine is hot - you need to test it.
Also you need to check for the start signal at the ECU, not at the ignition switch - the start signal comes from the wire that runs from the ignition switch to the starter solenoid to pull the solenoid in - it is connected to the ECU so that the ECU knows when the engine is being started, it should be at 0V (relative to chassis ground) whenever the engine is not being cranked.
There should be a service manual at Acks FAQ with details on what resistance the coolant temperature sensor should show at various temperatures.
Offline 1raddude
« Reply #7 on: November 22, 2016, 08:06:26 PM »
Ok ill get specs on temp sensor & trace the solenoid engage wire to the ECU make sure 0 volts to ground when engine is running got it Thank You for your help!
