Tire pressure-how much?
  • 17 Replies
  • 3622 Views
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
Re: Tire pressure-how much?
« Reply #15 on: March 19, 2004, 02:36:55 AM »
For the road I run 30PSI in my rear, 28PSI in the front.
My tires are okay to pressures of up to 35PSI by Sidewall reference.
This wears them evenly just fine.
For all you running PSI of door - umm, that's for STOCK tires -- just hoping you know that, because running a different size tire is definitely going to need a different pressure.
Also, running tires over the suggest PSI just seems dumb.
'87 TinTop
'04 F-150
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #16 on: March 19, 2004, 03:46:38 AM »
If your running stock tires go with the manufactures numbers.  They will inflate the tires to the max pressures to get the best gas milage out of them.  Then next will be the ride concideration.
OR
The best thing to do is just try a couple pressures and see how you like it and how it handles.
The important thing is that the oppsite tire has the same pressure in it.
When I'm on the road (32-11.5 tires) I run anywhere from 20-25.  Off road I run anywhere from 4 - 15 psi.  And if I'm on the low side I'll run a couple pounds more in the front because of the weight.  It'll give the same pattern as the back that way.
« Last Edit: March 19, 2004, 03:52:43 AM by lil_Truck »
32 MTR's Warn 8000i
Offline Mike71
  • 1449
« Reply #17 on: March 19, 2004, 06:50:00 AM »
i dont really know how the car is suposed to feel..the first car i drove was an 01 GV then my tracker and sometimes i bomb aroung in the womans 330CI...so to me my tracker handels like sh*t anyway u slice it..
right now i have 23psi and it doesnt feel like the side walls are flexing at all when i turn..i cant really tell if my gas milage went up untill i get the free gas outa the car and acctually pay for some(not waiting for that lol)
but thanks alot for ur helps guys much appreciated..hopefully next time i ask this itl be for 33"s =0 lol
