ok so, this is not my first kick or foryay but i am not an expert.
I bought a 1993 sidekick, spewing unburnt gass out the tail pipe.
I figured the motor was really worn and it needed a rebuild and I am fine with that diagnoses, it is a tin top, but its really clean, no rust, and i mean no rust, any way. check twice and dont fix whats not broken.
I brought it home and did a compression test at temp and it reads 155, 155, 155, 155. I am at about 1000 feet in elevation and that test does not seam horrible to me, well not proportionate to the issues with the rig.
I replaced the timing belt, adjusted the ignition rimming, checked the compression.
Here is the thing it is running on 1 and 4 with a weak fire on number 3 and nada on number 2, all 4 are getting spark, new plugs, oil, excetra. this is before and after all the above testing and replacing the timing belt none of the above changed.
during the testing i noticed that sometimes the misfires would stop and the motor would run clean, and then flood number 2 and 3, they are being fuel fouled, number 2 much more than number 3 but 1 and 4 are fine.
I am going to look at the injector harness and make sure no one did anything stupid, and then look at the injectors tomorrow, But i have not run across an issue where the injectors failed and flooded with fuel.
I will post pics and updates tomorrow evening, but i figured i would ask here, as this is what got me started with the zuks, and this forum was very helpfull building the first 2, i used to post as Mythose, but i lost acces to that email, any way let me know if you have any thoughts, I might coronary the vacume lines in the am as well but i think if it were a vacume issue it would effect all 4 not just 2 and 3.
