Reading on the forum about camber adjustment softer the 2 inch coil spacers, so I elongated my top holes a little. Then I flipped the steering knuckle out, and cleaned out the rust from behind and ground a little down from the back of the knuckle. That got me a little more too in total I got over 3/32 elongated hole for adjustment. Way too much. The top of the tires are 1 inch in compared to the bottom. Next time 1/8 might be enough. If you loosen both bolts and pus up on the brake rotor, you can get a few more thousandth as well. The way it sits I would have proper camber for a 4 inch lift
