Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998
Rear Main Seal
Rear Main Seal
jerrycampbell
3
ZUKIWORLD Online!
Rear Main Seal
April 19, 2016, 07:29:48 AM »
I need to have the rear main seal replaced. I am in the Corvallis, Or area. I am wondering if anyone knows who might be the best mechanic in the area to do the job?
Thank you
Jerry
'92 Tracker 8V, 1.6L, 5 sp, 4wd, 2dr, conv, CAMI
ranger88den
279
12
Re: Rear Main Seal
May 07, 2016, 10:29:39 AM »
Jerry, are you sure the rear main seal is leaking and not, the more common, valve cover gasket or distributor O-ring?
rascott
669
15
tread lightly monkeywrench a little
Re: Rear Main Seal
May 07, 2016, 10:20:21 PM »
also check condition of transmission input seal, while you're in there.
I found gear oil was mixing with motor oil.... replaced both.
sorry- no mechanic advice.
