NEED HELP!!!!CANT GO ANYWHERE
  • 1841 Views
Offline RideorDie
  • 52
« on: April 10, 2016, 07:25:57 PM »
 Hey Guys kinda new here dont know much about samurais either. Im having some troubles whenever i put my samuria into gear does not matter where i put it, neutral, first ,second etc it will not move. It feels like it is trying to move and it also sounds like its trying to move but it will not go anywhere. It simply bogs down and dies can someone please help me I am really looking to hit the trails CANT WAIT any longer
Thank You
Re: NEED HELP!!!!CANT GO ANYWHERE
« Reply #1 on: April 11, 2016, 06:30:43 AM »
We need to know more about your Sami.  What motor & drive train does it have?  What has been done to it recently?  Or when did it run last?
Offline RideorDie
  • 52
« Reply #2 on: April 11, 2016, 07:47:17 PM »
I do not know a whole lot about it I know it has a 1.3 liter in it and it starts and runs fine. No matter where I put the stick shift, when I let out on the clutch it sounds like its trying to move but it will not go anywhere, it does this in neutral and all gears, I think I am going to go ahead and put a new clutch, throwout bearing and flywheel in it hopefully that gets me somewhere
« Reply #3 on: April 12, 2016, 07:36:19 AM »
Thank You
I think all of that is a little premature, unless you have money you just want to spend.
First make sure the transfer case is in High or Low, basically either as far forward or back as it will move.  See if it will move.  If TC does not want to shift It may be stuck between gears, and is an easy fix.
With it running and in gear and have someone check to see if either drive line is turning (by laying beside sami, not in front of wheels).  Check the drive line between transmission and TC.
(If you list your location, it is easier to to find someone nearby that may lend assistance in person.)
« Last Edit: April 12, 2016, 07:44:01 AM by BRD HNTR »
« Reply #4 on: April 12, 2016, 04:02:33 PM »
Looks like you have a good reply on your other post.
And here is ZW write up. http://www2.zukiworld.com/feature_installation-repair-of-transfer-case-shifter-sheet/.
It helps if you know the name of your problem to do a search.  But that is what this board is good for, helping you learn, and not using a torch on you.
Good Luck,
