CALMINI Products: New Product Release C7 Winchguard Front Winch Bumper!
  • 0 Replies
  • 1609 Views
Offline CALMINI_Inc.
  • 104
  • The Leader in Suzuki Offroad
    • CALMINI Products, Inc.
C7 Winchguard Tube Front Winch Bumper
The new CALMINI Winch Guard bumper features 3/16" and 1/4" heavy duty plate steel throughout and 1.50" x .120" tubing. The bumper also has pre-drilled mounting plates and accepts most Warn and Ramsey winches up to 9000 pounds. The Warn ZEON winch will NOT fit on this bumper. Unlike other bumper designs, you are not limited to the style of winch used as both stand up and flat style winches will work perfectly. The front winch plate has precision laser cut holes for mounting your roller fairlead. Bumper provides additional tire clearance by removing stock outer mount tubes. Bumper can be used with any CALMINI suspension system and towbar kit...at the same time! This unit is finished in semi-gloss black powdercoat for corrosion resistance and comes complete with all mounting hardware.
https://calmini.com/detail.php?b=2&m=40&t=6&p=1257&n=
