CALMINI Products: New Product Release C7 Winchguard Front Winch Bumper!
  • 2335 Views
Offline CALMINI_Inc.
  • 104
  • The Leader in Suzuki Offroad
    • CALMINI Products, Inc.
C7 Winchguard Tube Front Winch Bumper
The new CALMINI Winch Guard bumper features 3/16" and 1/4" heavy duty plate steel throughout and 1.50" x .120" tubing. The bumper also has pre-drilled mounting plates and accepts most Warn and Ramsey winches up to 9000 pounds. The Warn ZEON winch will NOT fit on this bumper. Unlike other bumper designs, you are not limited to the style of winch used as both stand up and flat style winches will work perfectly. The front winch plate has precision laser cut holes for mounting your roller fairlead. Bumper provides additional tire clearance by removing stock outer mount tubes. Bumper can be used with any CALMINI suspension system and towbar kit...at the same time! This unit is finished in semi-gloss black powdercoat for corrosion resistance and comes complete with all mounting hardware.
https://calmini.com/detail.php?b=2&m=40&t=6&p=1257&n=
Offline pico42
  • 10
Re: CALMINI Products: New Product Release C7 Winchguard Front Winch Bumper!
« Reply #1 on: February 26, 2016, 05:23:35 AM »
Why no love for the Zeon?
Offline arced
  • 55
#1. At the following link or URL, you don't explicitly & exactly say what years & models your Product #SK5047 is good for:
https://www.calmini.com/detail.php?b=2&m=7&t=3&p=759&n=
#2. The top says "Suzuki 1999-2003 Vitara".
#3. The middle says "Finally, a true ROCKCRAWLER Transfer case gear set for for the Vitara/Grand Vitara/Tracker."
#4. The bottom says "1999–2002 Suzuki Vitara".
#5. Exactly what years & models is your Product #SK5047 good for????
#6. In particular, is it good for all models of Vitaras & Grand Vitaras thru 2002, including a 2.5 or 2.7 Liter Grand Vitara with a manual transmission????
#7. In regard to Chevrolet Trackers, since according to the website below, all of the Chevrolet Tracker T-Cases for all models of 2.0 Liter Chevrolet Trackers from 1999-2004 have a part number of either #91177379 for manual transmissions, or #91177069 for automatic transmissions, & all of the Chevrolet Tracker T-Cases for all models of 2001-2004 Chevrolet Trackers with 2.5 Liter engines have a part number of #91177069 for both manual & automatic transmissions, Calmini's Product #SK5047 should be good for all Chevrolet Trackers thru 2004. Do you agree or disagree with that????
http://www.gmpartscenter.net
« Last Edit: April 06, 2016, 10:16:10 PM by arced »
Offline arced
  • 55
According to Auto Parts Fair, Calmini Product #SK5047 should be good for all Vitaras with automatic transmissions thru 2004, but Vitaras with manual transmissions, & all Grand Vitaras might be different:
http://www.autopartsfair.com
« Last Edit: May 01, 2016, 01:21:33 AM by arced »
Offline arced
  • 55
To Whom It May Concern At Calmini:
Why are you afraid to answer my replies above????
