1996 Tracker 4D
  • 1067 Views
Offline Nonnie
1996 Tracker 4D
« on: February 02, 2016, 07:40:14 PM »
Runs great however a tapping noise when it first starts running. I checked for loose belts plus a smell like burning oil but no leaks anywhere. I checked the lines, looked underneath for leaks all dry. Any suggestions as to what to do next I will appreciate it. The tapping noise stops but when idle you can hear it too.
Re: 1996 Tracker 4D
« Reply #1 on: February 03, 2016, 08:44:49 AM »
The tapping noise is PROBABLY your lifters, they may need to be adjusted.  If your motor is stock, it uses a Belt to drive the valve train.  (FYI, On much later models they changed to using a chain with a tensioner to drive the valve train, and when the tensioner sticks or guides are badly worn, the chain has a tendency to break.  On those with chain drive when the rattle doesn't go away quickly it is a warning to change the chain and tensioner. It is not so with belt driven valve trains.)
On your 96 model, the timing belt does need to be changed out around 60,000 miles.  So if you do not know when/if the belt has been changed and mileage is over 60,000 miles it would be something to consider as needing to be done.
