Replace dash light bulbs
  • 1541 Views
Offline Kim Stone
« on: January 21, 2016, 04:36:48 PM »
Can someone advise where to obtain instructions?  Do I have to remove steering wheel to remove the light cluster?
Offline Capt
  • 738
  • 28
Re: Replace dash light bulbs
« Reply #1 on: January 21, 2016, 07:01:48 PM »
On what type vehicle?
On my 87 Sammy, the 4-way flasher button is in the way, but can be manhandled
to get it out, and pulling the steering wheel with a puller is fairly easy
Offline Kim Stone
« Reply #2 on: January 24, 2016, 08:43:36 AM »
It's a 1991 Zuki.  One instruction I read said remove 4 (surrounding) screws.  I could only find 2.
Thanks
Kim
Offline melbakid
  • 28
  • Hey, lets see what's over the next hill!
« Reply #3 on: January 24, 2016, 02:38:40 PM »
Just did the LED and white gauge face mod to my 88.5 TT cluster. The other two screws are on top of the dash. You will need a stubby Phillip's screwdriver to remove them. It's a snug fit pulling the cluster out. I dropped the column and pulled the steering wheel. It made it much easier ;D If you replace the lamps with LED's (highly recommended) I would not replace the Hi-beam indicator lamp. The LED is so bright when you are driving with your hi-beams on, the blue light will really glare in your eyes. I live out in the country and do a lot of driving with Hi-beams so it is a real pain in the butt having that blue light shining in your eyes. I have to replace my heater core, it just started leaking, so I will reinstall the standard lamp in the Hi-beam indicator. Just a heads up for you.
Good luck with your cluster.
There are only two types of Samurai's: Those we need and those we want!
9/13-Goldilocks-1988.5 Samurai Soft top-bone stock, 29's on 15x7's
2/15-Red Ryder-1988.5 Samurai TT-SPOA on stock springs, 29's on 15x8's, Calmini OTT, Kong II, 4.16 TC w/Twisted T, OME Steering stabilizer
11/13-1995 Sidekick 2WD 5SP 4DR (future parts car)
