window regulator
  • 1754 Views
Offline 4x4kingx889
window regulator
« on: January 08, 2016, 05:53:40 PM »
I have a 98 tracker which I installed a brand new regulator in and for the life of me I cant balance it right no matter what I do the windows gos up crocked and you need to use both hands to guide it up...I removed all the rubber strips lubbed everything up nothing is rubbing it that I can see and the window still goes crocked half way up any one know what I can do to fix this?
  • 4314
  • 167
Re: window regulator
« Reply #1 on: January 09, 2016, 02:07:50 PM »
Did you have to attach the regulator to the glass?  I haven't worked with this specific vehicle, but, f I recall correctly, having the regulator positioned incorrectly on the glass can cause problems similar to those you are describing - some fixtures allow you to slide the regulator along the bottom of the glass, if yours does, try moving it slightly in either direction.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline 4x4kingx889
« Reply #2 on: January 09, 2016, 06:52:14 PM »
yes I tried moving it all kinds of ways and still cant get it to work right
Offline Big O
  • 9
« Reply #3 on: January 21, 2016, 09:00:31 AM »
pull the front  guide out then try..
Offline 4x4kingx889
« Reply #4 on: January 24, 2016, 03:47:47 PM »
what do you mean by front guide?
