Samurai front axle 26 spline conversion
  • 3102 Views
Offline CCOR
« on: December 28, 2015, 07:10:24 AM »
I've got a 1988 Samurai at the shop with 22 spline axles in front.  Is there a make model, year that was equipped with 26 spline axle shafts that I can get shafts from instead of buying aftermarket chromoly axles?
Thanks,
Bobby
Offline sspence81
  • 6
Re: Samurai front axle 26 spline conversion
« Reply #1 on: January 02, 2016, 12:51:26 PM »
My 88 1/2 has 26 spline front axles.  I know because I just took my differentials to get new ring and pinion installed and I checked to see if the front and back were the same.
Offline Ruby
  • 26
« Reply #2 on: January 02, 2016, 06:34:21 PM »
All samurai stock fronts are 22 spline
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #3 on: January 05, 2016, 02:03:46 PM »
The Sammy with the 26 spline front axles probably has aftermarket axles in it and the side gears were swapped out with side gears from a Sidekick or Tracker to run the newer aftermarket (chromo?) axles.
« Reply #4 on: January 07, 2016, 05:40:20 AM »
All US samurais had 22 spline front axles, from the factory.
Usually people find 26 spline rear sidegears and swap in the front (or swap the whole third from a rear of a samurai into the front), in order to run the aftermarket 26 spline front axles.
