fuel cutoff reset
  • 1636 Views
Offline captwoody
  • 688
fuel cutoff reset
« on: December 22, 2015, 07:08:01 PM »
Does a 01 tracker 2.0 2dr 4x4 have a fuel reset switch for when you are in a collision? and if so where is it ? I was at an accident today and one of my fireman hit that switch on a car that was in an intersection so a lady could drive away. Then I thought to myself I don't know if I have one or where it was at.
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
  • 4314
  • 167
Re: fuel cutoff reset
« Reply #1 on: December 23, 2015, 03:49:28 AM »
It doesn't have one - the ECU senses when the engine stops and shuts the fuel pump off after a few seconds.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline captwoody
  • 688
« Reply #2 on: December 23, 2015, 01:17:14 PM »
Thanks Fordem I could not find one ,and after it is activated would not be the time to look for it. Since it is in my ECU do I wait for it to reset or use my OBDII to reset if it is activated
  • 4314
  • 167
« Reply #3 on: December 23, 2015, 02:13:17 PM »
There's no resetting - if the engine stops, for whatever reason, the ECU shuts the fuel pump down - when you turn the key to the start position to restart the engine, the ECU turns the pump back on - if the engine does not start, it'll shut the pump off again; if the engine restarts the pump will stay on.
