HELP!!! suzuki 4 dr 1997 front side window cranking problems!!!
  • 2867 Views
Offline mtnbowhunter
  • 27
« on: December 10, 2015, 05:27:40 PM »
HI GANG
I need advice on how to fix the front drivers and passenger side window cranking assy on my 97 4dr sidekick.
sometimes. probably 2/3 of the time when I roll the windows up they are fine until the top 2 to 3 inches and then the window kind of tips forward a little and jams and you can not finish cranking it up, you then ghave to manually straighten it and crank a little more,repeat,etc.
is there a way to adjust this by taking of the front doors panels so this does not happen????????? HELP!!!!
Re: HELP!!! suzuki 4 dr 1997 front side window cranking problems!!!
« Reply #1 on: December 11, 2015, 06:31:51 AM »
Check the window channel rubber make sure it's not missing or "bunching", and yes, you can open the door and adjust the position of the guides and whilst you're in there check the regulator itself to make sure the pivots are not binding and twisting as it approaches end of travel.
  • 27
« Reply #2 on: December 11, 2015, 09:06:20 PM »
Thanks for the suggestions.
the window rubbers,etc appear to be okay with no bunching,etc.
so if I remove the door side panels I can lube and adjust the assy. that the window hand crank operates????
any other suggestions
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #3 on: December 12, 2015, 12:16:02 PM »
When my windows start canting and binding as I attempt to roll them up, I pull the door panels and check to insure the regulator is snug.  If nothing is loose inside the door, I just order a replacement regulator and install it.
  • 27
« Reply #4 on: December 13, 2015, 06:14:58 PM »
if you are talking about replkacing a regulator I presume you have power/electric windows???
my Suzuki has hand crank windows.
« Reply #5 on: December 14, 2015, 05:45:11 AM »
Power or manual, both mechanisms are known as regulators, they are different parts, but the name is the same.
