ABS disable or delete
  • 0 Replies
  • 1884 Views
« on: November 16, 2015, 03:49:30 PM »
What is the best way to temporarily disable the ABS on a Sidekick Sport?  Putting a relay on the main ABS fuse seems excessive at 50 amps.  Can I switch the power to the ABS controller or the ABS pump relay and be able to run with the ABS off?  I can make  the circuit latch open when selected and fail to closed on power loss.  That way it will be normal at every engine start, preventing it from staying off all the time.
I am also having a periodic problem with the ABS, that I will post in the trouble shooting sub forum.
