Need help with x-90 lift
  • 12 Replies
  • 7767 Views
Offline tacobeam87
« on: July 29, 2015, 07:48:34 PM »
Have a 96 x-90, we put a 4.5" lift kit in it from rocky-road(2" body lift with 2.5" suspension). We were told 30x9.5 R 15 tires would fit but they massively hit the rear of the front fenders, can turn the wheel maybe 2 inches before it hits.
The tires are mounted on ion rims.
Anyone have this issue? do you have to cut and modify the fenders?
Offline captwoody
  • 688
Re: Need help with x-90 lift
« Reply #1 on: July 30, 2015, 08:41:00 AM »
on my 01 tracker i had to cut out plastic liners and pound in with sledge where it hit. then i was good to go
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
« Reply #2 on: July 30, 2015, 01:17:39 PM »
The X90 has less clearance than a Track/Kick, you will have to cut and bash or look into the Hagen mod.
Offline captwoody
  • 688
« Reply #3 on: July 30, 2015, 02:22:19 PM »
Bits for Brits also sells a cam bushing that moves the A  arm forward
Offline Spellspt
  • 14
« Reply #4 on: August 26, 2015, 09:54:08 AM »
4xfourart (EU) and AlteredEgo (Cdn) makes front arms that are bolt on, and move the from wheel 2cm-3cm forward.
Probably won't ben enough for those tires, but look into it.
http://www.alteredegomotorsports.com/tracker-suspension.html
Offline kreator
  • 634
  • 15
« Reply #5 on: August 27, 2015, 09:35:18 AM »
Most of us that build lift kits make the arm so the tire is an inch foreward
« Reply #6 on: August 27, 2015, 12:47:40 PM »
I built a pad to move the ball joint forward 1 1/2" & out 3/4" to allow fitting 33's, which still required modifying fender wheel arch.  Here is how I increased the wheel arch.  http://www.zukiworld.com/forum/build-diaries-how-to-diy/how-to-enlarge-tracker-wheel-openings/msg275274/#msg275274.
I was running 30-9.5-15's on my 93 tracker without moving the ball joint or cutting the fenders.  Obviously the X90 has much tighter clearances.
« Reply #7 on: August 29, 2015, 02:21:52 PM »
Offline ToyYoda
  • 226
« Reply #8 on: September 08, 2015, 05:36:34 PM »
I used a 4" cutting wheel & cut out aprox 3" of body. Did this infront & behind the doors. Then riveted in a 1" rubber flair. No more problems. BTW, Tires are 33'X10.5
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« Reply #9 on: September 09, 2015, 07:04:45 PM »
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Offline bgt2u
  • 44
« Reply #10 on: December 08, 2015, 06:03:04 PM »
I managed to put 35 12.50's on my X-90, with only a 2" suspension lift, and no body lift. You can get your tires to clear, by removing the inner plastic, cutting, and pounding back the fender wells (that your feet rest on, on the interior of the car). Then you can fiberglass over the cut area, to fill it in. You also will need to cut the fenders accordingly. I did not have to modify my a-arms either. Hope this helps.
« Last Edit: December 08, 2015, 06:08:11 PM by bgt2u »
Offline ToyYoda
  • 226
« Reply #11 on: December 28, 2015, 04:39:18 PM »
The body metal for a X90 is hard to come by. I highly recommend you don't "hack" it all up.  I would drop tire size before I gutted the complete fender .  I like to off road & for the effort I expect my X90 to out perform a stock one. Larger tires are a big part of the mod. But to limit turning while driving over dips & rough areas is not a option to go big.
Offline ToyYoda
  • 226
« Reply #12 on: December 28, 2015, 04:50:30 PM »
Here are a few examples of different tires on X90s with different lifts. Note; 3 of the 4 pictured have 3" body lift.
