I think the blower resistors go BECAUSE the fan motor is worn. The resistor is only a symptom of the actual problem. I think in most cases IF the fan motor is good, you shouldn't be blowing resistors. So when you have a blown resistor, replace the fan motor along with it and see if your resister goes out again any time soon.
I just bought a used Jeep today. Yep!... I sure did. I drove it several hundred miles bringing it home today. The Jeep's fan blower switch only works on the the 3rd and 4th setting. Nothing on the 1st and 2nd settings. I'm going to replace the resistor and the fan motor and see what happens, short term and long term. For a Jeep both items will cost me around $50. I'm betting I'll get even MORE air circulation from a new fan blower motor on the Jeep too.
