2002 build
  • 143 Replies
  • 47259 Views
0 Members and 29 Guests are viewing this topic.
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #120 on: September 29, 2016, 07:12:02 PM »
I was thinking of putting bigger coil spacers, like 2" instead of 1 1/2" in the front, unless I can find xl-7 springs for cheap ,as I had a set but everything is on hold so wont happen this year as wifes side of family screwed me over, and want to kill all. but that's another story. if you look at a xl-7 they sit bum high too
Re: 2002 build
« Reply #121 on: September 30, 2016, 03:17:57 PM »
Here is a good chart to compare the different OME spring options and how they compare to stock:
http://www.lowrangeoffroad.com/images/charts/front_springs_chart.jpg
Re: 2002 build
« Reply #122 on: October 01, 2016, 07:47:11 AM »
I have OME 962 springs in the front of my Sidekick.  I would prefer to change to OME 956 springs.  I don't have a V6 or a  bumper and winch to weigh my front end down.  If you are interested in the OME 962 springs, I can pull them out and order new ones for mine.
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #123 on: October 01, 2016, 09:12:19 AM »
those are the same size I got in now, but thx for the offer
Re: 2002 build
« Reply #124 on: October 01, 2016, 09:55:30 AM »
Are the same spring rate or just the same length?
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #125 on: October 01, 2016, 06:12:18 PM »
length is the same they came from a 99 Grand Vitara with a 2.5 manual they are a beefer spring that was stock
Re: 2002 build
« Reply #126 on: October 04, 2016, 10:25:34 AM »
I am running 956 (13" 500# rate) and a 1" spring cup modification.  Instead of a spacer you might want to think about modifying the spring cup to keep A-arm spring seat closer to same angle of top spring seat and prevent it from bowing.
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #127 on: October 04, 2016, 02:50:33 PM »
brd htnr I'm not coming down too see you if you are going to try and convince me that I need to do this.... lol . I would like to do the widing mod but lost welder and shop as moving in Nov1 ,but will have 2 car garage to play in
Re: 2002 build
« Reply #128 on: October 05, 2016, 06:44:50 AM »
When stuffing a wheel on inside turn, the spring would compress the brake caliper, and then not have brakes for two strokes.  Took a while to figure out what was happening.  You have 16" wheels, so that may change things,.  If you do run into occasionally no brakes on the trail, just stop stuffing the front end during turns. >:D
Looking forward to meeting up again. (So maybe only a few small suggestions, will be coming forth.)
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #129 on: October 06, 2016, 12:05:26 PM »
no 16" wheels, I still have 15" with the 30x9.5 and running bfg AT. Taking another trail run this weekend ...500+ kms and going to try the 4x4 out as I'm going hunting in a new place. When I get back from the final test run this should tell me if I can trust it to get me where I need to go. should be able to get down there mid November to mid December but I will PM you when I'm coming down
Offline Waterman
Re: 2002 build
« Reply #130 on: December 10, 2016, 07:28:54 AM »
Great job
Offline Perryd
  • 202
Re: 2002 build
« Reply #131 on: January 15, 2017, 07:11:32 AM »
I only just got around to reading this now, love the build. Make me think of what my 03 could have been like if it wasn't rusted to death lol. But I must ask, where's all the pics/vids???
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #132 on: January 15, 2017, 10:06:12 AM »
there was a bunch but after the site crash I lost the pictures that I posted, and got new comp where they were stored on. As of now she just sits in the driveway and drive it once and awhile, trying to save money for a couple more add-ons like the 3" extreme lift from 4xfourart, rear locker, transfer case gears, and 33"-32" tires
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #133 on: March 16, 2017, 04:54:38 PM »
well picked up some new shoes 33x12.5x15 cheap and tried the fitment test ......well they fit but the mule will be losing some metal around the fender area need 1"1/2 on the rear and 2" in the front hope I got enough room for it
Offline beagle..t
  • 1239
  • 16
Re: 2002 build
« Reply #134 on: March 16, 2017, 04:56:58 PM »
front tire pics and they stuck out abit
